Homefry RS2 Setup boost?
  • stevieyid
    • Apr 2005
    • 2251
    Be interested to know what boost people are running on the homefry RS2 chips? Im currently getting 1.3 bar tailing off to 1 bar at the red line. Also when driving i see vacume going off the scale which is minus 1 bar on idle its -0.8 bar is this about right?
    3'' Longlife Exhaust, Koni Adjustables, H&R Springs, Full RS2 Setup with Mr Nugents RS2 Chips (just need the RS2 Airbox)
  • A80Avant
    • 10873
    • Country: Greece
    on idle it should be around 0.4 to 0.5bar.
    you have a boost leak. check your hoses
    • lind4hl
      • Jul 2008
      • 2465
      eeh, what? you say an rs2 have 0.4bar on idle
      -0.4 i would say!
        RS2 homefry going to 1.3?
        It goes to 1.4 or 1.5 stock RS2 ecu AFAIK
        • stevieyid
          • Apr 2005
          • 2251
          yeah goes to 1.3 bar and then tails off to 1 bar. Not very aggressive then. Done a boost leak test and that did not show any leaks in the boost hoses. The PCV system was leaking though
          • lind4hl
            • Jul 2008
            • 2465
            my Dumpvalve was very atmosperic, i had 0.9bar max on standard ecu
              MRC chip the RS2 to 1.9 bar. If you have full 3" system and RS2 setup your car is nowhere near full potential
              • stevieyid
                • Apr 2005
                • 2251
                Im sure my dump valve is a recirc valve, could this be the problem?
                • A80Avant
                  • 10873
                  • Country: Greece
                  yes correction i meant vaccum
                  the figures i was referring to were on idle. ON afterrun mine also goes to 0.8-0.9 vaccum
                  • stevieyid
                    • Apr 2005
                    • 2251
                    I have a 3'' cat back system with no cats but standard downpipe
                      ahaha! so it's been limited so your running about 300-310 bhp then
                      • lind4hl
                        • Jul 2008
                        • 2465
                        mine were OEM recirc valve also, typo, sorry
                        • stevieyid
                          • Apr 2005
                          • 2251
                          So a 3'' downpipe thenis a must if im going to get the best of the map and the set up?
                            Yes sir, it will go like stink, I believe Paul has more aggressive homefry maps that you need afterwards to get the best of it.
                            I think the mrc high boost map is for the RS2 ecu only
                            • stevieyid
                              • Apr 2005
                              • 2251
                              I know this has been covered but where is the best place to get the 3'' downpipe? Am i right in thinking the S2 is 2.5'' and the RS2 is 2.75''? If so could this be the cause of the squeeling i am getting (although only slightly now)
