Yesterday was the first cold day of this winter and my Coupe's crankcase vent froze. The car wouldn't idle and start. When I popped the hood I saw that the engine was oily around the oil cap and under pressure. So I cleaned the crank vent hose and now there's the problem that the car idles rough...like some cylinders misfire.
Is it a passing problem? Do I have to check anything else after I clean the crank vent hose?
