Evening guys,
Here we go,
Right, To set the pic.
Driving along normally temp guage reads approx 1/4 (say 75deg) if not a littl less in this weather. Stop driving for traffic say and the temp goes up as normal and expected, fan comes on etc etc, all normal.
Anyone else get this. I can't believe that the engine runs at such a temp that it the rad is not running at 90deg even after a 40mile drive.
So today, changed the themostat just in case. refilled with coolant and water, ran it on the drive for about 30 mins, watching the guage and also kept checking the lower rad pipe (just behind the metal housing for the themostat) eventually as expected full temp water at that part of the pipe and the overflow(to the top of the tank) was flowing a bit of water, again as I would have expected, bled it as normal, hot temp from the fans inside the car etc etc etc.
All good, went for a little drie and again the temp would not budge over the 1/4mark while driving along, only when in traffic.
got home lifted the bonnet and felt the bottom pipe again - COLD??????
Let it run and hey presto hot and water flowing again as i am guessing the stat opened....
So the question is - IS THIS NORMAL??? Doesn't feel it to me. surely the themostat should be open once th car has hit full temp, doesn't seem right that the thing closes again when driving....
THought please ladies and gents. really doing my head in..
Oh and for all intensive purposes the car is driving normal just a little bit of hunting for revs at idle (even after cleaning the ISV)
Aaron
Here we go,
Aaron
You can zip-tie a bit of silicon pipe round it to sheild it if the boot is missing.
