Conrod bearings problem. Big one.
  • nemilosu
    • Nov 2008
    • 196
    • Country: Romania
    First :Merry Christmas !
    and now the big problem :
    i replace the original condrod bearings with kolbenschmidt new bearings.
    after that about 200 km was ok and after the oil pressure start to drop down and on acceleration (stationary) i heard a noise from conrods.
    i drive about 30 km with oil on minimum level and maybe a litle under.
    after the oil sump was open i find it this on the conrods from cylinder 3 (the bad ones) and from cylinder 4 (the scratched)
    the code from the bearings are :32643 and 74 696 600
    and the sputter one : 32761 and 71 656 600
    anyone have any ideea if the bearings are bad or is other problem ?
    thank you and sorry for my long post and my english.
  • AUDIS2avant
    • Jan 2009
    • 670
    • Country: Denmark
    Hmm to me it sounds like the wrong size bearings m8.
    Maybe the bearings is on +.25 oversize and the cranck is std size?
    • driftin jo
      • Sep 2007
      • 2222
      Don't you mean the crank was -.25 undersize and the bearings std size.
        did you check the clearances when you installed them?
        • nemilosu
          • Nov 2008
          • 196
          • Country: Romania
          i dind't check the clearance. the crank is std and the old bearings was std.
          the oil used is motul 10w40 sinergie 6100+ (if that matter's_
          • 20vQC
            • Aug 2007
            • 684
            • Current: Italy
            the oil is not a problem. May be a problem if you started the engine after replacing the bearings without purge the oil system, or as Error thinks... clearance problem because of wrong size bearings.
            - Looking for a S2
            - Lancia Dedra HF turbo i.e. (4sale)
            - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
            • nemilosu
              • Nov 2008
              • 196
              • Country: Romania
              i cranked without pos until the oil pressure rises.
              • nemilosu
                • Nov 2008
                • 196
                • Country: Romania
                and the questions naw :
                1. kolbenschmidt bearings are good ? or i have to buy some glyco's ?
                2. the crank is ok to be repaired ? or is have to be std ?
                • Pirvu Eugen
                  • Apr 2007
                  • 1978
                  • Country: Romania
                  Problem is that in Romania we cannot find Glyco's. Not the sputter ones at least.
                  Is interesting to find iff the Kolben schmit ones are sputter as they say.
                  • s2_bo
                    • Oct 2005
                    • 6067
                    Contact this ebay user for glyco bearings.
                    He can post from germany, he also stocks the whole range inc oversize etc. so tell him what you need and he can advise and supply.
                    91 S2 coupé - RIP
                    98 S8 - Luxury barge
                    • volcano rs
                      • Jun 2005
                      • 2265
                      kolbenschmidt bearings are good .there must be some other problem .
                      • nemilosu
                        • Nov 2008
                        • 196
                        • Country: Romania
                        i think so. anyway. i wiill rebuild the engine.
                        • caterpillar
                          • 2480
                          if you NOt have the oilfilter housing of the block; there are some isues with the valva in the oilfilter housing; and if you have a bad oilfilter ( bad sirkulation) in the oilfilter; you do not have the oill pressure ,and controll of the oilpump...
                          • nemilosu
                            • Nov 2008
                            • 196
                            • Country: Romania
                            i will change the oil pump.
                            i don't understand very well about the oil filter. can you be more specific ?
                            thank you.
                            • AUDIS2avant
                              • Jan 2009
                              • 670
                              • Country: Denmark
                              When u put the bearings in, did you lubricate them?
                              Could be an oil pressure problem.
                              Why did you change the old bearings?
