Went to check the oil and water yesterday and the water was down quite a bit, and some coolant under the car so looks like I have a water leak.
Goto start tracking down where it is leaking from now, what size and length is the small pipe on the water manifold? I was going to get a length of the pipe and some new jubilee clips in preparation if it is that part?
Also ive seen mention of the after run pump leaking, but only under pressure so will check that out too.
Looks a bit bloody cold out there at moment though.
