Auditude,
I don't think it would be wise to replace the rings if you do not plan to resurface the cylinder walls. The reason being "most engine rebuilders" put a 60 degree cross hatch pattern (x) on the cylinder walls to help the rings break in & seal properly against the cylinder walls.
If you do decide to replace the rings, you can still do the repair inside the engine compartment if you want to. Your just gonna need one of these. http://www.mytoolstore.com/kd/kdengi10.html
