3B conrod bearing update?
  • audiman
    • 4827
    I have been told about doing that too.
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • Doug_RS2
      • 3847
      The forces on the lower shells are not really any different to a car running standard power though - It doesn't cost any more, if at all, to use the same.
        No wear on my 3B small ends at 190k.
          The upper bearings on mine are a different colour to the lowers, darker metal, maybe someone did them before?
          • audiman
            • 4827
            Thats normal. Mine were same. New RS2 ones are also different colours. Cant remmber which was which, never bothered to look at them too hard as I had new ones to put in anyway. Been in stock for over a year now! LOL
            Audi UR Quattro
            • Keeper of The Kitten
              • Dec 2003
              • 2317
              Ok, so the main job to get sorted is the big end shells if the engine is coming out.
              Doug, are you saying I might as well get RS2 upper and lower shells, or just the upper shells? They need replacing as a complete set, yes?
              Regarding metal head gasket, you mentioned the need for a good surface finish on the head. What's the situation for the mating surface on the upper deck of the engine block, will that need some work too?
              __MDC__
              Martin Cutting
              • audiman
                • 4827
                Just make sure it is clean and free of imperfections. Yes replace both upper and lower shells.
                Audi UR Quattro
                  • Dec 2003
                  • 2317
                  Cheers Tom!
                  __MDC__
                  Martin Cutting
                  • diesel des
                    • 3896
                    #24
                    When did the change in bearrings take place? I have a aby, does this use the stronger bearings? Thanks, des.
                      • Dec 2003
                      • 2317
                      From what I've been reading here Des, it would seem that ABY lumps already come "hardened" to the higher outputs we're all craving!!
                      I've found a competent engine builder who has done reliable work on some racing engines for a colleague of mine. Next stop, buying some of those bits!
                      __MDC__
                      Martin Cutting
                      • Martynf
                        • 1885
                        Drop mer or Paul a PM about those bits, we tend to know most of them off the top of our heads these days!!
                        I think I'll put together a rebuild kit for the S2!!
                        Stage 1: upper rebuild head gasket etc
                        Stage 2: Turbo off, and head
                        Stage 3: The big one, everything! with cheese too! would you like to supersize those rods sir?
                        Martyn
                        www.vagparts.com
                          • Dec 2003
                          • 2317
                          Will do soon Martyn! Not sure I want everything with cheese just now!
                          __MDC__
                          Martin Cutting
                          • Martynf
                            • 1885
                            no worries, just a hamburger meal with standard fries!!
                            Martyn
                            www.vagparts.com
                            • audiman
                              • 4827
                              I have a full on cheeseburger at the moment. Thanks Martyn for arranging the solution to my problem. BTW, book the parts to Dads debit card
                              Audi UR Quattro
                              • Audi Parts Guru
                                • 1317
                                #30
                                Does he know yet Tom
