What should be the oil pressure in 3B, measured at 1000 rpm and oil temperature of 90 *?
oil presure 20Vturbo
Look for circa 2bar at running temp... More like 5bar at a cold idle.
Older engines can warm idle below 2bar of course but you should see well in excess of 4bar when revs are any higher than approx 2000 rpm.Paul Nugent
Think mine is getting worn then, as at tickover 800rpm on Pro-s 10W50, mine is just over 1 bar. If I take it to 1000rpm it creeps up to about 1.6bar... Assuming my stand alone gauge is correct...1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2004 A4 2.5TDi convertible, re-mapped to 180bhp
2011 A5 sportback 3TDi-Backbox delete, remap
Originally posted by 20Vcqdriver View PostThink mine is getting worn then, as at tickover 800rpm on Pro-s 10W50, mine is just over 1 bar. If I take it to 1000rpm it creeps up to about 1.6bar... Assuming my stand alone gauge is correct...1989 B3 2.0 3A 80 quattro... Budget 1.8T Project.
Originally posted by K Simmonds View PostI wouldn't panic to much, my old 10V coupe has only has 1.1 bar at warm idle, it's been like that for over 50K now and still runs perfectly. It jumps up to healthy pressure as soon as the revs increase.1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
