engine prob help please urgent
  • Azman
    • Sep 2005
    • 3205
    hi guys. On the phone internet at the moment. Engine is struggling at the mo stutering under light accel no power and really jerky. Was fine till i started driving to work pulled off at a roundabout and it happened. Once above 3k rpm is fine and holds boost so not a leak. Any suggestiors and what to check. Cheers aaron
    Dark Grey Avant
    RS2 FARB
    Alloy Subframe Bushes
  • terrybullwon
    • Mar 2006
    • 8782
    Do you have good voltage?
    Chef
      It could be a vacuum leak, check the DV, ECU connections
      • Rusty
        • 18953
        TPS? How does it go at different throttle positions? Does it idle OK? I remember leaving the TPS unplugged one day and it kangarooed along but idles fine.
        • GazzaG60
          • 4133
          o2 sensor.
            Is the MAF plugged in?
            • Azman
              • Sep 2005
              • 3205
              after stripping the coil cover have found 2 loose spark plugs got some new ones at home so walking to get then now. Voltage is good vaccum lines are all good too. Cheers guys. Think it may be a coil pack but that is next on the list to replace .
              Dark Grey Avant
              RS2 FARB
                Don't know, a coil wouldn't work under more load than less IMO
                • Knight Rider S4
                  • 3541
                  I agree with Jamo here , coils fail underload not the other way about ..earth issue maybe on the coils?
                  93 S2 Avant Parting
                  91 URQ RR
                  02 A4 tdi Avant
                  • Azman
                    • Sep 2005
                    • 3205
                    Problem averted and wallet battering not taken..
                    We changed the coil pack boots and put new spark plugs in (NGK ones as they were the only ones available at short notice) put it all back together and fire her up and bobs your uncle problem gone........ not a coil pack just one of the boots was letting it arc to the head...... Thank god for that at least the car had the decency to let me know something was amis instead of just chucking a spark plug up to the coil pack!!!! Can't believe that two were loose but all done and dusted now
                    Thank you for the idea's guys..
                    Oh and for good measure given her a good shoeing down the A5 just to check it was not a coil pack and she now purrs like a kitten and goes like stink again
                    Dark Grey Avant
                    RS2 FARB
