My S2 hit 3 Bar earlier...yikes !!
  • andyg plym
    • Nov 2006
    • 4646
    outside temp was 3 degrees C.
    Fairly short dual carriageway drive to the local tesco to get the bird some tat.
    Put the loud pedal down and the boost goes off the gauge
    The gauge is very reliable and it goes to 2 bar, but the needle flicked way past it, almost like another full bar!!
    The car slightly vibrates at this point, as in the back of my mind i always thought over 2 bar on a standard aby block you get the banana pistons???
    Spec is :
    Rs2 turbo,manifold,intercooler,green injectors,headgasket. Mapped by Minhea.
    What could be causing this?
    When i got the car just before xmas it drove ok, but then i replaced all hoses,pipes, clips etc and boost was noticably improved. holds 1.5 ish to redline if i remember seeing right.
    I know if i let this continue its going to cost me mega bucks. I know its cold, but it aint that cold
  • s2_bo
    • Oct 2005
    • 6067
    rs2 turbo cant make 3bar, not even if you have a 360 bearing and a bleed valve fitted which you dont have. Unless your running your car on some special fuel thats making the turbo spin 10 times faster...
    Sounds exciting though!
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • QuattroFever
      • May 2006
      • 1360
      does it do it everytime? or only the once?
      Volcano ABY coupe
      Ant
      • A80Avant
        • Sep 2005
        • 10873
        • Country: Greece
        what if a wastegate got blocked or something?
        • andyg plym
          • Nov 2006
          • 4646
          does everytime!! and i tried it on other gears too.
          it gets worse, its only on regular unleaded at the minute
          • s2_bo
            • Oct 2005
            • 6067
            91 S2 coupé - RIP
            • QuattroFever
              • May 2006
              • 1360
              what boost gauge is it? digital?
              id have a stab at the n75, pull it off and clean it and the connector.
              and check the line to the wastgate cap isn't split
              cleaning is free too.
              Volcano ABY coupe
              Ant
              • andyg plym
                • Nov 2006
                • 4646
                boost gauge is autogauge, its defo accurate as ive had it in all but 1 of my s2;s.
                WGFV looks fairly new. It would boost to just under 2 bar maximum, now way over
                • QuattroFever
                  • May 2006
                  • 1360
                  could the actual wastegate jam shut?
                  Volcano ABY coupe
                  Ant
                    1st disconnect the N75 valve and see if you still get that boost level. If you do you've got a stuck wastegate most likely.
                    Also are you sure on the wiring of the pipes? you say you put new pipes on are they all on in the correct place.
                    • andyg plym
                      • Nov 2006
                      • 4646
                      jamo most defo pipes are all in the right places. so wastegate possibly maybe stuck? Maybe needs a bit of lube?
                      • lini
                        • May 2007
                        • 159
                        • Country: Slovenia
                        I've made a mistake conecting N75 wrong way. Boost went past 2bar with K24 on some MTM chips. Shaking the needle ower 1,7 and at 2bar imediate koncking.
                        S2+AAN in progress (again), BMW 3 compact
                        • andyg plym
                          • Nov 2006
                          • 4646
                          il check, but it does boost fine
                          • dest
                            • 4287
                            Full boost on normal unleaded?! Dont you like your car or something?!
                            I NEVER use anything other than super
                              If there's aleak in the pipe to the WG or the WGFV the WG will not open, I'd suspect a pipe myself. also a few times lately when its very cold my WGFV has got stuck in closed position which means boost will go off the scale. Be really careful with this if you are on stock rods, this is the way to bend them.
                              Could be a hole in the WG diaphragm.
                              Edit, just remembered. The other thing I've had was a leaky WGFV which also caused excess boost.
