How does ECU decide about ignition moments, is it all in software, or is there some mechanical component on dizzy ?
Is any "fine tuning" on dizzy possible, or is it just "align the dots" ?
And, most important: is it possible that system operates one way before 4000rpm, and some other way after ?
Can I use strobo timing light to get make sure system operates ok ?
I'm searching the web for some in-deph resource that covers it all, but no luck so far.
All because I'm still having problems with my 3b>RS2 conversion - car makes max 0.5bar boost until 4000 rpm, and after that it flies.
Thanks, Mario
Thanks, Mario
