044 pump now fitted
  • GazzaG60
    • 4133
    forgot the file to take the edge of the small strainer to sit the pump in far enough.
    • Rocco
      • Aug 2007
      • 6393
      • Country: Spain
      Gary and me for example i have a 3B S2,and i´ve fitted the original RS2 fuel pump in my S2 3B basket fuel pump...without any problems.... and then i could install the 044 motorsport pump without anything more??
      thanks¡¡
      • Sonic
        • Jul 2006
        • 5514
        895 201 779 H Reservoir upper part
        895 201 531 A Strainer
        N 903 307 01 Adapter (Banjo)
        N 013 812 8 Sealing Washers (x2)
        N 011 069 1 Domed captive nut
        That look right? I'm not sure my pump came with a screw in fitting, i got it from James a while ago.
        S2Forum.com Administrator
        • GazzaG60
          • 4133
          ah the infamous screw. the pn is on the forum somewhere. on a post where a guy had his misisng. calling andrew page will help. i got it from andrew page. they are bosch providers. its a 20 odd quid part IIRC.
          i got a 2 pump setup from an escort WRC and neither had the fitting.
          the list looks good. my etka is not showing much 3b. maybe too new. its got aby everything.
          Rocco. yes if you have a 3b pump holder in already its an easier swap. the aby pump is about 2 inch across compared with 3 inch or so on the 044.
          • Sonic
            • Jul 2006
            • 5514
            #20
            Cheers.
            For anyone wanting this bosch part number 1 587 010 532
            • Rocco
              • Aug 2007
              • 6393
              • Country: Spain
              #21
              thanks for all the info here
