Motronic ECU don't speak to me
  • hub
    • Mar 2010
    • 72
    • Country: France
    Hi,
    My S2 3B doesn't start since one month. Since my baterry was low (I have forgotten to turn off the stereo...), I have recharged it but impossible to start the engine.
    - the fuel pump turns
    - I heard also the water pump for about 5sec
    - all the lights on the ODB are OK
    But no sparks .... So I have tryied to communicate with the ECU motronic and there is an error communication...
    So I have looked on the workshop manual and they said to : "consult CFD to check earth connection" what does it means?? and where to check (ok for the inlet manifold for the pump)
    Some ideas... I hope the ECU is not dead
  • Le S2 Audi
    • Jul 2009
    • 3805
    Have you tried to reset the ECU??
    Pull out the fuses...
    May help?
    New S2 - S8 & RS2 -RS6 Keyrings
    • quattro20v
      • Jul 2007
      • 173
      Any immobilasator/alarm installed?
      Now quattro less, my urs4 stolen 13.8
      • hub
        • Mar 2010
        • 72
        • Country: France
        No alarm...
        I have put off the fuses to check if they are ok... It is enough to reset or should I make an ignition on??
        ps: There is no mapping on the ECU, it is full stock
        • Rocco
          • Aug 2007
          • 6393
          • Country: Spain
          check the distributor complete or the single coil
          sometimes the hall sender it is dead
          • hub
            • Mar 2010
            • 72
            • Country: France
            Is it possible that someone here send me a picture of the hall sender location on thé engine because Im not really sure
            • hub
              • Mar 2010
              • 72
              • Country: France
              But I don't understand why the ECU doesnt communicate even if the sender is dead.
              • Foeglass
                • Apr 2009
                • 68
                does your equipment read / get contact with the other ecu's? airbag/ecu/climatronic ect?
                And i saw somewhere it's possible to get the codes out with a led light / blinker codes?. correct me if i'm wrong
                "95 Audi S2 Coupé
                "02 Audi A8 6.0L W12 Quattro
                "01 Audi A8L 6.0L W12 Quattro
                "94 Audi Cabriolet 2.8 (in bits 'n pieces)
                • hub
                  • Mar 2010
                  • 72
                  • Country: France
                  Yes it is possible to read by plugging a light near the driver sit... (I don't have try actually)
                  I don't have airbag on my car (don't exist on 3b I think)
                  About the climatronic it is different from the motronic itself
                  • Knight Rider S4
                    • 3541
                    on a 3B you will only beable to get codes from engine controler as others not a function on 3B model
                    Things to check
                    Fuse 17
                    Main fuse for ECU as if it is dead you will get nothing
                    From the start of your problem as in battery losing charge I would look at the simple things first
                    Hall sender is built into distributor... 3 prong plug
                    93 S2 Avant Parting
                    91 URQ RR
                    02 A4 tdi Avant
                    • hub
                      • Mar 2010
                      • 72
                      • Country: France
                      hi,
                      Where is the fuse 17 plz? main fuse box?? here in red?
                      • hub
                        • Mar 2010
                        • 72
                        • Country: France
                        • M_GORDON
                          • Oct 2008
                          • 1295
                          • Home: Isle of Man Current: Vatican City State
                          Originally posted by hub
                          Some Fuses are behind a "cap"
                          photobucket SUCKS
