Motronic ECU don't speak to me
  • M_GORDON
    replied
    Originally posted by hub
    Some Fuses are behind a "cap"
  • hub
    replied
  • hub
    replied
    hi,
    Where is the fuse 17 plz? main fuse box?? here in red?
  • Knight Rider S4
    replied
    on a 3B you will only beable to get codes from engine controler as others not a function on 3B model
    Things to check
    Fuse 17
    Main fuse for ECU as if it is dead you will get nothing
    From the start of your problem as in battery losing charge I would look at the simple things first
    Hall sender is built into distributor... 3 prong plug
  • hub
    replied
    Yes it is possible to read by plugging a light near the driver sit... (I don't have try actually)
    I don't have airbag on my car (don't exist on 3b I think)
    About the climatronic it is different from the motronic itself
  • Foeglass
    replied
    does your equipment read / get contact with the other ecu's? airbag/ecu/climatronic ect?
    And i saw somewhere it's possible to get the codes out with a led light / blinker codes?. correct me if i'm wrong
  • hub
    replied
    But I don't understand why the ECU doesnt communicate even if the sender is dead.
  • hub
    replied
    Is it possible that someone here send me a picture of the hall sender location on thé engine because Im not really sure
  • Rocco
    replied
    check the distributor complete or the single coil
    sometimes the hall sender it is dead
  • hub
    replied
    No alarm...
    I have put off the fuses to check if they are ok... It is enough to reset or should I make an ignition on??
    ps: There is no mapping on the ECU, it is full stock
  • quattro20v
    replied
    Any immobilasator/alarm installed?
  • Le S2 Audi
    replied
    Have you tried to reset the ECU??
    Pull out the fuses...
    May help?
  • hub
    started a topic Motronic ECU don't speak to me
    Hi,
    My S2 3B doesn't start since one month. Since my baterry was low (I have forgotten to turn off the stereo...), I have recharged it but impossible to start the engine.
    - the fuel pump turns
    - I heard also the water pump for about 5sec
    - all the lights on the ODB are OK
    But no sparks .... So I have tryied to communicate with the ECU motronic and there is an error communication...
    So I have looked on the workshop manual and they said to : "consult CFD to check earth connection" what does it means?? and where to check (ok for the inlet manifold for the pump)
    Some ideas... I hope the ECU is not dead
