90Q ABY Conversion - Help please
  • simyboye
    • Nov 2007
    • 168
    Hi there,
    Working on my 90Q and have a few questions regarding the conversion. Tonks, where are you when I need you?
    1.Earth from coils - where should it go? The cable is about 100mm to short to reach anywhere, do I extend it?
    2.Brake vacum/ servo - how do I get round that? My 90Q is vacum but the ABY is hydraulic? Can I tap into the IM?
    3.Boost controller N75/ loom cable? - Wheres that little ******? Is it on the original ABY loom?
    4.Earth from bottom of engine? Where does it fit? Not long enough.
    5.90Q main wiring/ S2 ABY main wiring? Had a sniff round S2central and need some more wiring drawings, does anyone have any?
    Many thanks
    James
  • PeteUr
    • Jan 2010
    • 331
    • Country: Togo
    if its an original connection there must be a place for it rather than extending it, have you looked on etka, it might show on there.
    Not 100% sure about this, i'd probably do a setup same as the s2's but remove the bomb out the equation which would just mean getting a s2 avant brake master cylinder.
    Yes it will be on the loom
    How big is the earth cable? is it a gearbox earth, or different one?
    What bits you wanting to know, btw congrats on getting it started.
    Sapphire cos running custom 2.8litre conversion,es cos rims,raven black leather interior and 500+ with the gas turned off.
    Audi s2 cooking on gas
    • re2500
      • May 2007
      • 2185
      I have ABY converted CQ and i use the vacuum assist (more reliable IMO)
      Just tap into the IM. I also fitted an inline one way valve so air can only travel from the servo into the IM, not back. I have been told this is not 100% required as you would only brake normally off boost. But i think it is good to have.
      Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
      "Difficult is worth doing"
      • Tonks4x4
        • Nov 2005
        • 3062
        Give me a call if you want.
        Audi Nut!!!
