hey guys just wanted to know the differences between the two turbos and power differences, whats each turbo capable of through experience, and the hp rating for each want to get an idea of what to run maybe, looking at 500whp or more let me know what you guys think, appreciate it
HX35 vs Hx40
look into DSM forums and Honda forums in the US. loads of info there about power. on the I5 only Nervas used a holset on a custom made hotside modified K24 and stroker engine. Billman did the same on a HX40 with 56mm comp. wheel and made on 1.2 bar about 400hp crank(estimated measurement with the perfomance box).
Im going to be using a HXsuper40 (60/82 comp wheel). no results yet. -
i think if i dont use it my bro will end up using it i will let you know ok.
advantages of this turbo?Comment
yes, i was wrong,it is 60/84.
advantages? very good spool, very stongly built(as it is made for diesel trucks), easliy repairable anywhere, 360thrust bearing, and according to various dyno's i have come accross, spools as fast as a BB 3076R garrett and produces the same power as a GT35. That's good enough for me.
as i said, i will be tuning it the following weeksComment
thanks for the info and vid i drool over audis, cant wait to get mine done and show you guys !!Comment
Yeah more Holset Thread
Go 4 the HX40 if your target is 500 plus wheel powers ! The HX35 might be a little stressed
Looking fwd to hear some results then ...Comment
yes deff gonna do the HX40 and from there can move on, havent really seen any big turbo aan over here in the states, i have to bring some europe to them and show them how you big boys do it
hotside options are the original one, a K26 modified or the 0.70AR T3 one that i got from the US. Have no idea what it will do as far as spooling is concerned, but i have some input that it is much better than the original units on spooling time.
As for the boost required to get it going, all i have as info on the I5 is 1.3bar of boost making 400hp on a normal ADU engine on safe map.Comment
