HX35 vs Hx40
  • euro_urs4
    • Nov 2008
    • 267
    • Home: Poland Current: United States
    HX35 vs Hx40
    hey guys just wanted to know the differences between the two turbos and power differences, whats each turbo capable of through experience, and the hp rating for each want to get an idea of what to run maybe, looking at 500whp or more let me know what you guys think, appreciate it
  • A80Avant
    • 10873
    • Country: Greece
    look into DSM forums and Honda forums in the US. loads of info there about power. on the I5 only Nervas used a holset on a custom made hotside modified K24 and stroker engine. Billman did the same on a HX40 with 56mm comp. wheel and made on 1.2 bar about 400hp crank(estimated measurement with the perfomance box).
    Im going to be using a HXsuper40 (60/82 comp wheel). no results yet.
    • euro_urs4
      • Nov 2008
      • 267
      very well, will check that out thanks
      • Jcarrick
        • Mar 2010
        • 54
        I read on the other thread that you have an Hx35w. IF you end up going with an Hx40 would you wanna sell your 35?
        • Billman
          • 4129
          Super 40 has 60/84mm comp wheel.
          Go Holset or Go RS4
          • euro_urs4
            • Nov 2008
            • 267
            i think if i dont use it my bro will end up using it i will let you know ok.
            advantages of this turbo?
            • A80Avant
              • 10873
              • Country: Greece
              yes, i was wrong,it is 60/84.
              advantages? very good spool, very stongly built(as it is made for diesel trucks), easliy repairable anywhere, 360thrust bearing, and according to various dyno's i have come accross, spools as fast as a BB 3076R garrett and produces the same power as a GT35. That's good enough for me.
              as i said, i will be tuning it the following weeks
              • A80Avant
                • 10873
                • Country: Greece
                this is another HX40 example
                • euro_urs4
                  • Nov 2008
                  • 267
                  Originally posted by A80Avant
                  http://www.youtube.com/watch?v=WIUHhIZdYu0
                  thanks for the info and vid i drool over audis, cant wait to get mine done and show you guys !!
                  • chipsenter
                    • Jun 2009
                    • 246
                    • Country: Norway
                    Yeah more Holset Thread
                    Go 4 the HX40 if your target is 500 plus wheel powers ! The HX35 might be a little stressed
                    Looking fwd to hear some results then ...
                    FEEL THE DIFFERENCE
                    -Audi S2 " The Sleeper" 704hp 880nm
                    -Audi S2 ""Audi S2 Racetrack
                    • euro_urs4
                      • Nov 2008
                      • 267
                      yes deff gonna do the HX40 and from there can move on, havent really seen any big turbo aan over here in the states, i have to bring some europe to them and show them how you big boys do it
                      • GazzaG60
                        • 4133
                        whats the hotside on the hx40? always had this down as the weakness. maybe just presumption.
                        how much boost do you need to run to get into the efficiency of the unit.
                        • richardk
                          • Sep 2009
                          • 276
                          i have a holset super40 also, built in going to be next winter
                          • A80Avant
                            • 10873
                            • Country: Greece
                            hotside options are the original one, a K26 modified or the 0.70AR T3 one that i got from the US. Have no idea what it will do as far as spooling is concerned, but i have some input that it is much better than the original units on spooling time.
                            As for the boost required to get it going, all i have as info on the I5 is 1.3bar of boost making 400hp on a normal ADU engine on safe map.
                            • GazzaG60
                              • 4133
                              depends on the 0.7 stages too.
                              mines a 0.63 stage 5. spools later than a stage 3. mines also known as t350
                              best to avoid the klu-klux-klan so im told.
                              id expect the same. i calculated 438hp at 1.3 bar on mine around 7k.
