injectors?
  • euro_urs4
    • Nov 2008
    • 267
    • Home: Poland Current: United States
    injectors?
    ok so now i have a question about injectors, what do you guys recommend as in brand, and how big should i go, going to be running a HX40, and trying to get the most power out of it, my question is it bad to get bigger than what your aiming for to be safe? what did you guys do
  • Jonas_R
    • 3780
    • Country: Denmark
    Deleted...
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    • GazzaG60
      • 4133
      hx40 about 550hp?
      id go with seimmens 630cc. tried and tested
        Stick with the Siemens there is a better set out there but the siemens are tried and tested.
        • euro_urs4
          • Nov 2008
          • 267
          what are issues if the injectors arent big enough not enough fuel to the motor then assuming? would it be better to get say 700cc to be safe
            You want the smallest possible to achieve your bhp level ideally as it makes idle easier to acheive, if your not bothered about idle and low end running then you can have bigger injectors
