Arrrgggh...o-ring woes...WTF.
  • Greenm3
    • Jul 2004
    • 512
    Any help Please...how the hell does this come off....
    Its the bolt/screw on the right hand side of the intercooler, just by the o-ring...with the bush on it ....looks tricky and i dont wann rip anything....i.e incur another little job to do....im sure alot of you will have seen this before!!
    Im not so good at this internet thing but i think there is an attachment with this post with a photo......
    Cheers for the help...
  • sps-si
    • Apr 2004
    • 107
    if im in the right area its a 6mm hex bolt into a captive nut.
    bit of wd and wang it off.
    Simon.
    S.P.S. TUNING
    '93 ABY S2.... sold
    me thinks RR URQ next :mischeif:
    • sal_s2
      • 1288
      Unscrew that bolt with the bush thing on it from underneath. I think it was a 6mm allen key that I used.
      • Sidspud
        • 1223
        Yeah, but the whole thing starts spinning if the captive part is knackered. I seem to remember having problems with this. You'll need to grip the nut at the same time.
        ex '93 Avant owner
        • porkkis
          • 1994
          A bit of metal brush + penetrating oil before even trying to open it. You can also use pliers to prevent the nut side from twisting. And when it's open take the x-member to someone who can weld a bit reinforcement.
            Been there, broke that !
            Paul
            • Greenm3
              • Jul 2004
              • 512
              Right got that off after a bit of swearing and disturbing the neighbours!!
              Now....the o-ring is safely in the bin and im gonna attempt the o-ring and the Pipe mod....will post on progress later...
              Cheers for all your help wouldnt have figured that out for a while,....
              • martinjs
                • 3205
                I was gonna say just cut it off, once the reducer pipe is fitted there is really no need for that bolt anyway, i just left it out when i fitted mine
                martin
