Appropriate EGTemperature
  • Kroegarn
    • 92
    Just got my EGT gauge installed, with the sensor in the downpipe. I´m now wondering what the recommended max temperature at WOT is? The sensor is placed after the turbo (about 10 cm from the turbine)?
    I know that with the sensor in the manifold a temperature of about 950 is okey. It should not rise above 1000 degrees celcius.
    Made one short test late yesterday night and got about 600 degrees at WOT (only one test though). Idle temperture was about 400 degrees.
    The car is running a bit rich that could probably lower the temperature as well.
    /Mike
    /Mike
    S2 RS Avant@355hp "For sale"
    A4 Avant TDIq@170hp
    Datsun 240Z@550hp
    BMW M3 race car@321hp
    Garage
  • Doug_RS2
    • 3847
    if it goes over 800 degreesc C you are starting to run too hot. 750 on prolonged WOT is a good max temp to run at - I think I am running about 750deg C on WOT.
    • Kroegarn
      • 92
      Okey, thanks for your answer
      /Mike
      /Mike
      A4 Avant TDIq@170hp
      Datsun 240Z@550hp
      Garage
      • Albert
        • 1500
        • Country: Poland
        why are You instali the egt temp in downpipe ? it sould be just before the turbo
        AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
        • Kroegarn
          • 92
          Pure laziness Just got the car togheter and I have only driven about 3000 km in 1,5 years.... so now I want to put some mileage one the car The sensor will be moved when the engine needs a rehaul or repairs that require removal of the manifold.
          /Mike
          /Mike
          A4 Avant TDIq@170hp
          Datsun 240Z@550hp
          Garage
          • SteveH
            • 4460
            850 is the upper limit you would want to see after the turbine. I don't think it would be wise to run this sort of temp for prolonged periods of running. This will be somewhere in the region of 950 before the turbine. If you go much higher than this, something will melt
            91 Modded 3B
            14 A6 Avant Black Edition
            • Albert
              • 1500
              • Country: Poland
              it tepends on what type of turbo he has ... for a stock turbo i would say 100 C for a big K27 150 C. But the purpose of egt is to monitor the engine temp ... not estimate ...
              • Doug_RS2
                • 3847
                EGT meter should not be before the turbo as they break up and you don't want a thermocouple going through the blades. It is common for turbo cars to have them after the turbo and 100deg C drop through the turbo is a common figure used.
                • audiman
                  • 4827
                  I agree, Greg had one break off pre-turbo. Luckily it went throught the wastegate!
                  Tom C - www.rcmr.co.uk
                  Audi UR Quattro
                  Audi 100 C3 2.0 5 cyl 115ps
                  Audi B5 RS4 645ps 911nm
                  • Albert
                    • 1500
                    • Country: Poland
                    If You have it after the turbo it wont be acurate ... i use Greddy and till now its holding fine
                    • audiman
                      • 4827
                      Personally after spending over £1000 on a race spec'd K27 i dont want to risk damaging it. I will be fitting EGT gauge AFTER turbo into the downpipe. Max reading should be 850 anymore and kiss goodbye to the turbo. IMHO.
                      When mine was running lean after curing a boost leak temps after turbo increased to 900 before I backed off (as advisd by Mihnea).
                      Basically, if you work on circa 100 deg less after the turbo then thats close enough. ITs not ideal, but its safer.
                      Audi UR Quattro
                      • Albert
                        • 1500
                        • Country: Poland
                        It is safer not to tune the car at all ...
                        • S2-racer
                          • May 2004
                          • 247
                          but that would be no fun albert, lol!
                          and the reason most of us are here on this forum!
                          all sounds a little technical for me right now, but given time........
                          '92 S2 - Bent now
                            Come on Albert - give the guys some slack - it is MUCH simpler to install the EGT after the turbo. Sure in an ideal world it would be in front of the turbo, but the 100 degree guidline is good enough in this regard. EGT of 850 celsius after the turbo is sufficiently safe and accurate in my opinion. The additional accuracy of measuring EGT before the turbo in a road car does not warrant the risk of causing catastrophic damage to an expensive turbo in the event of the temperature probe breaking off... In MY opinion - and seemingly some of the other guys here as well.
                            Paul
                            • RSCoupe
                              • Dec 2003
                              • 120
                              How about mounting the probe at the entrance to the wastegate? That way if it does break off, there is a better chance it will exit thru the wastegate instead of the turbo?
                              Mark Siggelkow
                              '90 CQ 20vT - NASA GTS-5 (R.I.P.)
                              '90 CQ-R - NASA GTS-4/5
                              '00 A4 1.8TQMS (Wife's Daily Driver)
                              '12 TT-RS (Wife's new DD, on order for May European delivery)
                              '62 Porsche 356B (another race car)
                              '03 Kawasaki Z1000 (toy)
