I was able to get some information from a fellow member about the splicing. But, I was wondering if anyone could tell me what color wire pin 18A(full time power for ECU) and 25A(part time power) on a 90q b3 wiring harness?
Also, for the fuel pump I just followed the green/yellow wire and spliced into that. Was that okay? I heard that I might need a different relay because its only a K jetronic instead of KE jetronic; is this true?
I know pin 40 is the tach signal for the AAN harness but wire should I splice into on the 90q wiring loom?
