Coolant thingy leaking
  • Crawford_S2
    • 1555
    Found a slight coolant leak today from what looks like a pump, it has a hose that comes off the tophose of the rad going to it then one that goes to the block? It is in the engine bay behind the main rad under the inlet manifold. Its about the same size as the idle control valve. Is this the afterun pump or summit else Can't do any pics cos its dark now, any ideas
    Ragusa Coupe gone!
  • martinjs
    • 3205
    Yes that is the after run pump, the outlets are plastic so are prone to cracking i think.
    if you replace it make sure you dont overtighten the jubillee clips or it will break again
    HTH
    martin
    • Crawford_S2
      • 1555
      Cheers dude will get in touch with Vagparts for a price soon, but may leave it till after my holiday. More enthusiasm but less cash always works better for me!!
      Ragusa Coupe gone!
        Just remember that if you get stuck in a traffic jam and it all gets very hot, thats when it will blow and you'll lose all your water pretty quick.
