After my last service MRC told me that among other things I needed a new cam cover gasket.
So being tight I decided I'd change it myself. I found a guide on s2-audi.co.uk and bought a gasket kit from quattro corner. I followed the guide and had it changed within a few hours. The guide was great, it covered everything and was very useful and I'd recommend attempting the job to anyone with a box of tools!
My old gasket was leaking down the back of the engine and a little bit by the injectors, so if you can see oil in a similar area and you use a lot of oil then it might be worth checking yours.
Since I have changed it my oil consumption has dropped dramatically!
So a job well worth doing if needed.
