3b crank bolt torque
  • s2driveruk
    • 12696
    Hi just to confirm, is the torque on the bolt 350mn or 450mn, using the correct audi locking tool but need to set the bar crrectly.....
    david
    1992 3b S2 Coupe
  • Gazjen
    • Oct 2008
    • 223
    450Nm mate, no locking agent.
    URQ 20vt converted
    80 quattro saloon with on going a V8 transplant
    • Billman
      • 4129
      for the ABY in S2Central site states that it need 200 something plus some degree! What is correct?
      Go Holset or Go RS4
      • Jonas_R
        • 3780
        • Country: Denmark
        In my 3B manual it states that it should be 450 Nm and use some blue loctite (the one that does not require heat to loosen it).
        Sleeper S2 Avant +450
        A6 Avant 2.7t Stage 3
        Audi S2 Coupe RS2'ed
        • s2driveruk
          • 12696
          yep spot on Jonas, thats exactly what we did...car is almost ready to run again, just the fan to sort out now :-)
          Roll on Grusch
          1992 3b S2 Coupe
            The torque is 1 Stef + a 1m scaffold bar
            • s2driveruk
              • 12696
              Stef was out of stock that weekend so we made do with a monster 1000nm torque wrench rather than a torque wench (only jesting Stef!)
              1992 3b S2 Coupe
                Talk wench
                • s2driveruk
                  • 12696
                  1992 3b S2 Coupe
                  • Wiell
                    • Aug 2006
                    • 146
                    450nm with copper lub. doesnt now if that is the right word for it. been driving whole last year with it. and a diamond coated washer between the crankshaft and the "remhjul". (dont now the word sry)
                    if you use loctite you get much friction when tighting it and dont get the right torque.
                    • Jonas_R
                      • 3780
                      • Country: Denmark
                      And copper lubricant does not effect the friction?
                      If you by copper lub. mean copper grease as you use on wheel bolts, then that would help to lower friction and thereby you would torque to much.
                          I'd not be copper greasing the crank bearing any time soon... if a wheel bolt can work its way loose with copper slip on it then a crank bolt sure as heck can too.
                          Be sparing with the loctite, you don't want the bolt ot loosen but it would be nice to be able to remove it too
                          • Jonas_R
                            • 3780
                            • Country: Denmark
                            Iagree but if you use the blue loctite, then it is possible to get it off again.
