Ignition Issues
  • s2_bo
    • Oct 2005
    • 6067
    Ignition Issues
    Hello,
    Not been on here much lately, due to house move and no internet yet.
    My S2 seams to have some ignition issues, After its been stood for a while it wont start properly.
    It does fire up just, but sounds like its only running on 2 or 3 cylinders, theres plenty of black smoke and unburnt fuel coming out the exhaust and it the throttle is closed it stalls straight away.
    I have never replaced the POS or coil (3b engine) so maybe thats the issue.
    Testing spark at the plugs ends is temperamental.
    It also seams that when it does run for a while and gets warm everything is fine.
    This only happens if the car is left for about a month.
    Anyone else experienced this?
    Has this happened to someone else?
    91 S2 coupé - RIP
    98 S8 - Luxury barge
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    if you need any pos to check, i have one maybe 2 left(from rs2)
      Check condish of the rotor too
      3b coil has an external pos unit but is not pin compatible with aby adu setup
      do a quick impedance check on coil primary and secondary
      alternatively good be a bad earth
        Stock plugs or something odd ?
        • Pembo
          • Aug 2004
          • 295
          I removed the POS units and fitted these 'Red Top' coil over pack. Excellent results. Best modification I ever did. Smoother, reved quicker and never missed a beat.
          Pembo
          quattro - Original 4WD rallying
          Rally Car photos
          • s2_bo
            • Oct 2005
            • 6067
            plugs are Bosch platinum, leads are magnecore KV85's, dissy is about 5 years old in ok condition but the cap is new.
            Could be a bad earth. I'll investigate that, would it be on the wiring from the coil and pos?
            How do I check the coil primary and secondary? I'll have a look on s2central when I get to the Internet. (on the phone atm)
            Thanks for the help.
            91 S2 coupé - RIP
            • Flat on my back
              • Jan 2007
              • 2449
              Sounds like a water/damp issue to me...leads/cap/rotor...
              Might just need a good blast to warm and dry everything out, try that first.
              Carlos.
              • SteveH
                • 4460
                Mine does exactly the same thing after not being used for a while.
                91 Modded 3B
                14 A6 Avant Black Edition
                  moisture in the coil i think, i used to get this with my CQ until it became a garage queen
                  Hair dryer or a good run cured mine....... until the next time.......
                  • 4WheelDrifter
                    • Oct 2004
                    • 5773
                    • Country: Devon
                    I have 5 POS's and coils here if you want to try one Bo.
                    It's a shame I don't have a working 3B for you to try your coil on.
                    SS
                    • s2_bo
                      • Oct 2005
                      • 6067
                      Cheers guys.
                      Haven't got any time to come and borrow one Stu but thanks for the offer.
                      Has anyone else got a pos and coil I could borrow to see if it sorts it out?
                      91 S2 coupé - RIP
                      • s2_bo
                        • Oct 2005
                        • 6067
                        Some results today finally.
                        I tried a few different coils but it wasn't till i changed the spark plugs that the car sprang to life again.
                        When testing the sparks in some of the plugs the spark seamed to be jumping further up inside the recess of the plug and not at the gap.
                        I tried a new set and its now running fine with the maf unplugged.
                        As soon as the maf is plugged in the engine cuts out so it must be another dead one.. The Maf is pressure side mounted and fitted in to a 3" alloy maf body.
                        I will have to get another MAF to dismantle and place in to the body. I think its maybe the soldering that kills them as this is the second one thats died for no apparent reason...
                        91 S2 coupé - RIP
