fun time
  • bernsaudi
    • Feb 2007
    • 592
    fun time
    I have a 380hp rated turbo(that was on an ABY), ecu, injectors. If I bolt all this on, I assume my engine should perform. It already is up to 290 odd, and I have the 3inch miltek on already, but should I put rods in before doing this, or should the engine cope if driven respectfull of the change?
    Ta!
    Which turbo have you got? You will more than likely need a remap before you use the new turbo though.
    • Acidburn
      • 13459
      speak to hoffer76 as he could help out here
      • bernsaudi
        • Feb 2007
        • 592
        this one....
        5326-101-5160
        v.t 109-6
        any ideas?
        • hoffer76
          • Mar 2008
          • 230
          rs2 turbo or rs2 hybrid by the looks
          • bernsaudi
            • Feb 2007
            • 592
            just found this number on the hotside.......
            5326 101 6367
            the aet plate has vt 109-6 on it.
            • bernsaudi
              • Feb 2007
              • 592
              Am i right in thinking that if I bolt this onto my car now(it is mapped on a stock turbo to a good 290), it will run like a bag of the proverbial? I will need to get it mapped, so if you can help, thanks a lot :~)
              • T2Andy
                • 1903
                you might want to change the fuel pump to a higher flow one , bosch 044 .
                • bernsaudi
                  • Feb 2007
                  • 592
                  Is it necessary to get rods, or can I take care with it do you think?
                  • 20vQC
                    • Aug 2007
                    • 684
                    • Current: Italy
                    dunno... the compressor side looks a bit small to be rs2. I can't find any turbo with those codes, it's from the k26 family for sure, with a weird and small exh side...even smaller than a mc2's k26 I think
                    - Looking for a S2
                    - Lancia Dedra HF turbo i.e. (4sale)
                    - Typ89 Coupè quattro, 20Vt AAN, VEMS, K24-7000@1.3bar (scrapped )
                    • driftin jo
                      • Sep 2007
                      • 2222
                      mc2 is a k24
                      • T2Andy
                        • 1903
                        Rods should be ok ,theres many a mapped RS2 on standard rods ,its high tourque at low rpm that can bend rods ,also spark hop on the 3b engine ,i have 425 lb\ft on a k26 turbo and still going well on stock rods
                        • hoffer76
                          • Mar 2008
                          • 230
                          cold side is same as rs2
                          below a pic of one of mine
                          • T2Andy
                            • 1903
                            and not driven respectivly ...
                            • bernsaudi
                              • Feb 2007
                              • 592
                              so its injectors next then.....anyone got a set?
