One way valve in the block
  • A80Avant
    • Sep 2005
    • 10873
    • Country: Greece
    well yours is a 'modified vehicle' isnt it?? haha
    • AndyP
      • 6049
      Originally posted by Jamo
      Are you using ARP main studs?
      If you are and you have not got the stud with the cutback thread it is possible you have screwed this in two far stopping the check valve screwing in correct.
      It is also possible to crush this valve with the arp stud
      It's why the later 034 ARP's have a special cutback one.
      Yes I have the ARP studs from 034 with the one that is shorter.
      • AndyP
        • 6049
        See, never throw anything away
        Now refitted I'm rapidly running out of excuses not to fit the thing!
        • AndyP
          • 6049
          Looking at the AAT block, there is no way this can happen as the mains stud does not come thought the same hole as the one way valve goes in. Must be a 3B / ABY thing only.
          • T2Andy
            • 1903
            Come on get the damn thing in .i cant waits no more
            • G60Rallye
              • Dec 2006
              • 1321
              I was going to get a pic showing the stud passing into the oil way but forgot, its only a couple of mm but obviously enough to cause the damage shown in the picture.
              • Phil Payne
                • Jul 2009
                • 328
                Originally posted by Pirvu Eugen
                Iff you look at one end off the valve has torx, so use a adequate torx key and screw the valve in the hole.!
                The picture looks much more like triple-square than Torx.
                • Audi_CQ
                  • 940
                  • Country: Norway
                  #23
                  That picture bring back some bad memories
                  The "accident" happend with a 2.5 AAF block.
                  • Billman
                    • 4129
                    #24
                    For the later AEL block do we need 2 or 1 check valve. The picture is showing old and new?
                    Valve goes to the lower sensor isn't it?
                    Go Holset or Go RS4
                    • AndyP
                      • 6049
                      I used these 2, and yes, they go in the lower of the 2 holes. Insert the valve with the spring sticking out and then screw the sensor in on top of it.
                        Sorry to add to this thread so late but the check valve below is NOT TORX. For those who can count, Torx has 6 (six) points, not 12. (Only a factor of 2 out, not bad )
                        The check valve below uses a triple square bit (which is different than a double hex at the shape of the points).
                        • Tom_
                          • Oct 2007
                          • 1301
                          • Country: Czech Republic
                          #27
                          i read a lot of about it, but i am not clever from it. I have AAT 5 cylinder block. Should be removed, changed or checked?. I read about oil pump failure and there https://www.s2forum.com/forum/techni...l-pump-failure was lot of about long main stud/bolt on no.3 so now i am little confused, what is need to do with this problem on stroker aat engine block
                          Cheers,
                          Thanks
                          Audi Coupe Quattro 2.3 20V
                          • Thuppu
                            • 4115
                            You can use which valve you want, but if you use ARP main studs the one needs to be shorter so it doesn't squish the valve. No problem with normal bolts.
                            • Tom_
                              • Oct 2007
                              • 1301
                              #29
                              Thanks Tom, i want to use normal 12.9 grade steel or stainless bolts.
                              • Thuppu
                                • 4115
                                12.9 is ok, stainless hmm maybe not.
