CAM wobble or optical illusion
  • MGaz
    • Feb 2008
    • 698
    anyone else think the cam shaft has got a wobble to it?
    TYPE-85 Coupe Quattro: clicky
    2.5L GTi engineering RE2500 190hp.180lb
    Schrick 272 cam
    C A C 2.5" T304 Exhaust
    ITG filter
  • JP
    • 1858
    It's a cast camshaft that then gets ground on the journals and lobes. The journals and lobes will be 100% other than wear and tear. However the casting may potentially not run true for the simple fact it is a rough casting with irregularities. Not uncommon with machining from the early days. See it with flywheels aswell. You can clock them up 100% true on the lathe and then the minute you spin it up it visually looks like it is wobbling all over the place. Again all you are seeing is the irregularities in the casting.
    UrS6 Stroker + HTA3586 =
