Are they all like this ?
    For a giggle, I will remove mine to see what gives. Never tried having it off before
    • urS6Tom
      • 773
      Originally posted by PistonBroke
      I find that the revs are a little slow to drop on my ABY engined S2. What I mean for example is that when changing from 1st up to 2nd you have to wait longer than I think you should for the revs to fall to the appropriate level to match the higher gear and make a smooth gear change. If I let the clutch up too early there are just too many revs for a smooth change. Before anybody asks, yes I do take my foot off the gas !
      I'm just talking normal driving as well - not 6k plus or anything or rapid shifting.
      It's not so bad in the higher gears but it's very obvious betwen 1st and 2nd. Maybe there is a bigger gap between these two than the others but are they all like this - is there anything that could cause the revs to fall so lazily, any simple mods to help.
      It's a stock engine but has been chipped (not homefy) - could that affect it.
      What kind of exhaust do you have? When I upgraded to 3" turbo back it was really noticeable (and annoying) that the revs took longer to drop off. I backed off the TD adjustment all the way and it improved a lot but i had to alter my driving style a little to make gear changes smooth. Then I got a bigger turbo and I reckon it's now slightly better.
      • PistonBroke
        • Dec 2008
        • 118
        It's just a standard exhaust system.
        I think you're right about changing driving style, we have a couple of other cars that we use and the difference is quite noticable in the S2 after driving the others - but only really when changing up from 1st to 2nd. You just have to make the change quite slowly if you want to be smooth ... and I would much rather be smooth than a jerk
        I'll try and check out the previous suggestions - cheers guys, and see if I can make any difference.
