28 psi (2bar) boost on RS2'd 3b?
  • PeterS
    • 423
    Trying to help out a friend who does not post here...
    he is running MTM 3b RS2 code on his 1983 Turbo Quattro Coupe (UrQ)
    As he states, he's very concerned about potential spark hop running the distributor.
    Any one running this level of boost on a 3B?
    Any recommendations on reducing the boost to a "safe" 22psi?
    (thinking adjustable V Map instead of Bosch 3 bar Transducer in the ECU
    I'll forward the responses.
    Thank you
    -Peter
    Date: May 18, 2010 12:44:26 PM EDT
    To: "200q20v list" <200q20v@audifans.com>
    Subject: 28psi
    I've posted this question on the urq list, but this list would probably
    have some additional experience.
    I have an RS2'ed 3B in my '83 urquattro
    RS2 turbo
    RS2 exhaust manifold (extrude honed)
    Head is extrude honed.
    RS2 exhaust cam
    RS2 injectors
    RS2 MAF
    Pauter rods
    Adjustable fuel pressure regulator
    New distributor with metal gear and correct small tip rotor
    Porsche 951 intercooler
    Can you safely run 28psi on a 3B?
    I'm sure the hardware is good for it, but I'm concerned about the spark
    jumping over to an adjacent cylinder in the distributor cap under high
    boost conditions.
    Is anyone doing it and keeping the distributor?
    Mike
    Peter S
    1990 ErsatzS2 - track toy
    1991 Coupe Quattro
    1991 Coupe Quattro
    1995 S6 Sedan
    1995 S6 Wagon
  • aronmatic2
    • 2129
    • Country: Hungary
    are you serious? 2bars with rs2 turbo?
    Real carbon parts for S2 and RS2. Check Carbondesign on facebook
      Yep been done before with Sal_S2 and SteveH car, gives approx 400 bhp
      MRC do a high boost chip set that goes to 1.9bar on the RS2 turbo
      Very aggressive setup and fast too!
      • PeterS
        • 423
        Mike describes the acceleration as "violent".
        28 psi measured on his manual boost gauge.
        I haven't had a ride yet in his Urq, I have had a ride in Javad's 80tq, so it will be interesting to compare the seat of the pants feeling of "violent" :-)
        Jamo - Sal and SteveH's car - 3b or ABY engines?
        Again, the issue here is spark hop with the dizzy, any experience on how to potentially dial down the boost?
        Peter S
        1991 Coupe Quattro
        1991 Coupe Quattro
        1995 S6 Sedan
        1995 S6 Wagon
        • aronmatic2
          • 2129
          • Country: Hungary
          shame on me.
            Boost is ecu controlled, if the ecu is requesting this boost then there's little you can do to stop it getting there. You could put in a weaker WG spring I suppose or run of purely mechanical boost.
            Sals was ABY
            SteveH was 3B, it ended with the rods bending as they were stock
            I'm sure S2_Bo is running 1.9bar on his 3b setup with an RS2 turbo
            • PeterS
              • 423
              Mike has carrillo rods so at least they are stronger than stock...
              Understand that the boost is controlled by the ECU..
              Wondering if switching from the Bosch 3 bar to the adjustable VMAP would essentially dial back the boost.
              Peter S
              1991 Coupe Quattro
              1991 Coupe Quattro
              1995 S6 Sedan
              1995 S6 Wagon
              • porkkis
                • 1994
                You can fool the ambient pressure reading to lower the boost if the functionality has not been disabled in the boost sw. This is also the way factory did this in "trailer mode".
                MAP signal adjustment works too of course for limiting, but it may also add some odd part throttle boost behaviour.
                I've mapped a 3B with gt71 garrett compressor, 2,2 bar boost between 3500 and 5000 rpm and no spark problems what so ever. This has been running for years now.
                  I've only seen "trailer mode" on the RS2 ECU. I have thought before about using a pot to replace the altitude sensor for some form of manual boost control but never had the time to play with it. Its on the long list of things to explore
                  I would say if the dissy, rotor arm, coil are in good condition (and correctly aligned) then a 3B should be OK with high boost - especially if uprated rods are fitted. I cannot remember if SteveH 3B suffered a bent rod because of simply huge torque or if sparkhop induced it.
                  • denniselbows
                    • 740
                    i'm sure spark hop results with the combination of high boost and a worn dizzy .if i remember correct the sport quattro,s1 evo 2 and the pikes peak car all ran dizzys and they all had massive power levels
                    never set your expectations to high that way you are never disapointed
                      If your worried about spark hop see this thread by a4kquattro http://www.s2forum.com/forum/showthread.php?t=29457
                      • 20vQC
                        • Aug 2007
                        • 684
                        • Current: Italy
                        well maybe the pauter rods are doing well the job! the weak point of the engine has been solved and now holds a lot of torque and a minor spark hop...in the case he's using the stock 3b one... it's my opinion
                        - Looking for a S2
                        • SteveH
                          • 4460
                          The rods bent in my motor when we got to 2.1 - 2.2Bar! There was no indication of spark hop or missfire.
                          It was during a mapping session that helped Mik define what was too much for standard rods and the RS2 turbo However it was also a good excuse to rebuild the motor with a set of Carillos
                          91 Modded 3B
                          14 A6 Avant Black Edition
                          • Rocco
                            • Aug 2007
                            • 6393
                            • Country: Spain
                            i was runing in my 3B a software from Hamon Motors for RS2 specs with of course RS2 turbo and YES 2.0bar in 4th and 5th gear ,without any problems and the AFR were between 11´3 / 11´8 with RS2 injectors and 7A FPR in WOT.
                            and 1´8bar in 3rd gear....
                            • EspenW
                              • Apr 2007
                              • 1534
                              • Country: Norway
                              Worn dizzy gear will be a major culprit when it comes to spark hop. If the gear is still plastic, replace it with a metal one ASAP.
                              Doubling the boost on an engine will increase the peak cylinder pressure by only 20%, so going from say 1.1 bar to 2.2 bar increases the peak load by only 20%, far less than the loading from even mild pinging/knock. However, turning up the boost increases heat and thus the chance of knock, exhaust reversion, preignition,etc and this can put the engine over its limits.
                              The average cylinder pressure will increase by more than 20% when doubling the boost, but it is the peak value that determines the load on components.
                              Timing is a lot harsher, going from say, 10 degrees to 30 degrees will triple the peak cylinder pressure.
                              1994 80E Avant
                              1986 2L Golf 2 on Alcohol
