Trying to help out a friend who does not post here...
he is running MTM 3b RS2 code on his 1983 Turbo Quattro Coupe (UrQ)
As he states, he's very concerned about potential spark hop running the distributor.
Any one running this level of boost on a 3B?
Any recommendations on reducing the boost to a "safe" 22psi?
(thinking adjustable V Map instead of Bosch 3 bar Transducer in the ECU
I'll forward the responses.
Thank you
-Peter
Date: May 18, 2010 12:44:26 PM EDT
To: "200q20v list" <200q20v@audifans.com>
Subject: 28psi
I've posted this question on the urq list, but this list would probably
have some additional experience.
I have an RS2'ed 3B in my '83 urquattro
RS2 turbo
RS2 exhaust manifold (extrude honed)
Head is extrude honed.
RS2 exhaust cam
RS2 injectors
RS2 MAF
Pauter rods
Adjustable fuel pressure regulator
New distributor with metal gear and correct small tip rotor
Porsche 951 intercooler
Can you safely run 28psi on a 3B?
I'm sure the hardware is good for it, but I'm concerned about the spark
jumping over to an adjacent cylinder in the distributor cap under high
boost conditions.
Is anyone doing it and keeping the distributor?
Mike
Thank you
-Peter
Subject: 28psi
RS2 turbo
RS2 exhaust cam
RS2 injectors
RS2 MAF
Pauter rods
boost conditions.
Mike
However it was also a good excuse to rebuild the motor with a set of Carillos
