How to check timing with Strobe Light or VagCom
  • Jonas_R
    • 3780
    • Country: Denmark
    Hi,
    I need to use check my timing so I can enter the correct number in VEMS under "TDC after trigger".
    I know this can be done using a strobe light, but where do you aim the strobe light at? Is it the small window at the flywheel?
    I know that I can use VAGCOM to see what the timing is, and I remember reading that on a warm engine timing should be 10 degrees at idle.
    So if VAGCOM reads 11 degrees is in then correct that my timing is 1 degree off and then I could correct VEMS with 1 degree or is it stupid doing it this way?
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
  • Jonas_R
    • 3780
    • Country: Denmark
    Anybody that knows where you aim the strobe light?
    • saltinot
      • May 2004
      • 1946
      Jonas, I would think you should be pointing the light at the flywheel through the hole in the gearbox. That's normally how you set the timing on older models.
      See you soon!
      • Jonas_R
        • 3780
        • Country: Denmark
        Thanks Tom, I will give that a go
