Still a non runner
  • Polish
    • Feb 2008
    • 126
    Still a non runner
    Sorry to be a pain replaced the hall sensor in the dizzy and the drive gear still no spark i need help or any other suggestions or it will be for sale as a non runner 1992 3b
  • terrybullwon
    • Mar 2006
    • 8782
    Checked to see if the fly wheel pin is still there?
    Chef
    • HMS-S6
      • Jan 2010
      • 1164
      Am i right in thinking that the 3b cars can break the distrubutor drive?
        It can happen - broken drive cog.
        • Polish
          • Feb 2008
          • 126
          drive cog ok new tonks4x4 has had a look and is puzzled too
          • spink
            • 4382
            Check camshaft sprocket hasn't snapped its 'key',i had this and was scratching my head for several days.When the starter was turning the engine the timing was moving out of line slightly and then returning to its proper place once still,but as always best place to start is to check the codes.
            • SteveH
              • 4460
              A very likely culprit if you haven't checked this already. I had the pin snap off on mine and it's relatively common problem.
              91 Modded 3B
              14 A6 Avant Black Edition
              • Polish
                • Feb 2008
                • 126
                How easy is It To check the pin Is In the Flywheel?
                • Tonks4x4
                  • Nov 2005
                  • 3062
                  remove the 2 sensors and bracket together from the side of the gearbox. Then use a zip tie or a piece of soft wire and poke it into the hole just in front of the flywheel (engine side) then crank it over you should feel the pin tap it on each rotation.
                  Audi Nut!!!
                  • Polish
                    • Feb 2008
                    • 126
                    Cheers will try that today thanks again for your help the other night
                    • Polish
                      • Feb 2008
                      • 126
                      Right Checked the pin on the fly wheel and that is there all the teeth are on the fly wheel the key on the cam whel is there so am i right in thinking that it can now only bo the 1 of the 2 sensors on the bell housing?
                        No codes?
                        • Smiley
                          • Jun 2005
                          • 329
                          In the case you don't already know, here's how to ..
                          '93 Audi S2 Avant panthero black, 412.000km
                          '94 Audi S4 C4 Avant 303Tkm, KW, Brembos, BN-Pipes, Bose, S6 front (sold)
                          '93 Audi S4 C4 Avant, 260Tkm
                          '88 Audi 100 Avant turbo 44Q
                          '84 Audi 80 quattro tornado red
                          • chezz
                            • Apr 2007
                            • 440
                            Is the hall sender receiving power?
                            • Polish
                              • Feb 2008
                              • 126
                              the one on the dizzy is new but the old one was ok too found out after i had fitted the new one so i either need to get a vag com code reader done or do i replace the two sensors on the fly wheel or does anybody have 2 that i can try to eliminate those?
