Gents,
I'm trying to get my afterrun circuit working correctly. The car is a urS6 1996. I've changed the afterrun pump and this morning the temperature sender from the coolant rail.
Still no afterrun.
I bridged the wires of the temperature sender and no pump and no fan.
Now I want to find the fuse and the relay. I've searched and some threads say it's in the passenger footwell kick panel. I can't find this so can someone give me better directions please?
Shane
EDIT: Just inside the passenger door on the left hand side theres a plastic panel that looks like it's 2 panels. Just behind that.
Still no afterrun.
Shane
found it, Relay no 324 (447 965 571A). There are 3 fuses in there and all are fine. From reading about this previously I thought these relays failed on the switched on position thus causing the battery to loose all charge.
the infamous fuse from the 1996 UrS6 after run system
I was sure i'd found the fuse too, located in one of those slots beside the relay itself. It sure would seem like an obvious spot for it. More
