Cam Pulley Wheel
  • jogi730
    • 2335
    Cam Pulley Wheel
    Just spotted some concerns about the pulley wheel being a weak point and prone to failure.
    What replacement non OEM part is recommended that can be obtained fairly quickly?
    Many thanks
    Chris
    Audi 90 quattro (Typ 85)
    20v turbo conversion
  • GazzaG60
    • 4133
    not sure chris.
    ive seen the dahlback one. its wasn't cheap and had a waiting period when i asked. in the end i used the faxtory.
    • terrybullwon
      • Mar 2006
      • 8782
      Chris the OEM one is bloody strong! DBR is a tommi's bullet they are not so good very soft. And a mild steel woodrough key
      Chef
      • jogi730
        • 2335
        Many thanks James. Just read what happened with Sleeper Avant and Jamo's comments which alarmed me somewhat. I thought I also read something about you fitting a Pace one (probably mistaken as a bit confused with all that is going on at the moment ).
        Chris
        • Billman
          • 4129
          What about the red 034 one? Has also hall sensor window!
          Go Holset or Go RS4
          • terrybullwon
            • Mar 2006
            • 8782
            I have pace pulley wheels indeed, I will give you the low down on msn soon
            Cheers James
            Chef
              I take the DBR over the OEM
              • quattro
                • Dec 2004
                • 768
                And i would take OEM over DBR one, my DBR one is sat on my parcelshelf may or may nor mod it with a stronger woodruf key like james did.
                Probably the longet S2 project in history EVER!
                  Did you ever fit it though? James is the only one on here that had a problem with it and there's a lot of members using it without issue.
                  Yet there are a lot of reported failures with the OEM one so the logic to me just doesn't add up.
                  Ask AndersS2 and Sleep Avant, this OEM part has failed and taken out their engines.
                  I checked my DBR after said Terrybullwon scare and there was nothing wrong with it the fact i've seen it used on 1200 bhp strokers leads me to believe their is nothing wrong with the DBR wheel.
                  • GazzaG60
                    • 4133
                    think im with jamo although i cannot say yay for dbr i know the factory ones if not treated properly or even the slightest slip is 40 odd quid down the pan.
                    think we need VAS to x-ray them fgor us first as im almost sure the damage is already done on most of them.
                    there are other wheels. for instance the 16v wheels etc but they dont clear the cam sensor. they are shaped different. i tried it. also the 16v wheel from a kr or 9a/6a is a lot, lot stronger in this area.
                    • quattro
                      • Dec 2004
                      • 768
                      Yes i did fit it and the wodruff key didnt fit perfectly imo, after i torqued it up and ran it for a week i had to take it off (not related to pulley wheel) and the soft alloy was slightly damaged so i decided not to use it.
                      • GazzaG60
                        • 4133
                        so thats the same as factory then. they have movement and that turns into a broken pulley.
                        • merlin's S4
                          • Jan 2005
                          • 1539
                          Check out this link and click on camgears. There's one there that looks identical to the 034 one which is compatible with the hall sender.
                          Choosing the right domain name can be overwhelming. Our personalized customer service helps you get a great domain.
                            http://www.rosten-performance.com/
                            Looks nice, one problem for me it looks like it uses the OEM hall ring so has the same issues as the OEM cam wheel IMO
                            Would have to find out if the woodruff key is hardened or not
                              Fair enough
                              9 second drag car check the cam wheel
