no spark or injector pulse! Any ideas please throw them in.
  • Sleeper_Avant
    • 2372
    as topic really lads,
    after putting my head back together AGAIN it wouldnt start, weird....
    checked all the earths etc and still no good, ripped all the wiring out to check inline fuses and all is good.
    my Hall Sensor bracket has always been broken and im hpoing thos this is all it is, new one ordered from TPS (£135+ the raggy!!!!!)
    anyone throw any other ideas into it??
    injectors are live at boths terminals, getting 4.99volts at the plug and resistance is 6.10 at the sensor wth plug disconected.
    if it aint the hall sensor im breaking it! sick to death of stupid things costinmg me a fortune.
    HELP!!!!!!!!!!!!!!
    1993 URS4 Avant Emerald Green 350+bhp
    1991 Ford Sierra Sapphire 4x4 in Magenta
    BoooOOOSSSSSTTTT BANG BANG CHIRP CHIRP
  • Sleeper_Avant
    • 2372
    at the hall sensor plug*
    • Billman
      • 4129
      hall sensor
      Go Holset or Go RS4
      • Gazjen
        • Oct 2008
        • 223
        Timing Pin on the back of the flywheel or sensor not seeing/US
        URQ 20vt converted
        80 quattro saloon with on going a V8 transplant
        • pixsaudisex2
          • Sep 2004
          • 3110
          Definatly got all the coil wires connected correctly.and the pos. an your earths.
          • GazzaG60
            • 4133
            mine failed when i did the cam swap. the slightest knock.
            • Sleeper_Avant
              • 2372
              brand new hall sensor, ftted it and no problems there but still no running,
              both crank sensors at bellhousing have no live feed, i think the ECU has given up to be honest.
              any other guesses?!
              anyone after an AAN motor complete?
              • kirvis
                • Feb 2010
                • 262
                • Home: Lithuania Current: United Kingdom
                how much for the motor?
                • Sleeper_Avant
                  • 2372
                  Everything for "conversion" is £1500
                  loads of new engine bits within 2 months, head rebuild etc etc etc
                  please dont turn this into a for sale thread lol
                  • kirvis
                    • Feb 2010
                    • 262
                    hmmm... i can get my engine rebuilt for £1500
                    • Sleeper_Avant
                      • 2372
                      try to buy an engine on its own then, there normally £1000-£1200 depending on spec
                      • gnutz2
                        • Aug 2006
                        • 928
                        HELP!!!!!!!!!!!!!!
                        Strange, injectors should see 12 volts not 5 and resistance sould be more like 12 ohms.
                        The two crank sensors do not have any voltage to them they are variable reluctance sensors and generate their own voltage when running on a tooth wheel.
                        HTH
                        The ONLY S2 Golf!
                        10.42@138mph
                        • kirvis
                          • Feb 2010
                          • 262
                          someone tried to sell one for "£700.. unlucky
                            Remove the starter motor and check the pin is still in the flywheel
                            • Sleeper_Avant
                              • 2372
                              HTH
                              yeh injectors are seeing the 12v supply ( typing non too accurate lol)
                              even when cranking theres no pulse.
                              very interesting about the non live feed at crank sensors cheers for that!
                              Jamo, will check first thing tomorow
                              I still think its a huge co-incidence its only happened since ive had the head off, will do a continuity test on the wiring from the ECU tomorow.
                              got my head pickled this one
