any vr6 swapped S2's or CQ's out there?
    Originally posted by my2000apb
    when you say the vr6 hhad its days in the 90's, those were 12v's!!!!!!!!!!!
    24v will outlfow the 12v by epic amounts
    Your most likely right but what has happened is the tuning scene really has shifted to the 1.8t engines as the common transplant.
    They even put them in Lotus cars.
    The willingness to use the VR6 really has really gone,
    In the 90's it was get a VR6 into the car, now it's get a 1.8t in it
    Golf MK2 owners now shift between the R32 and 1.8t lump
    • my2000apb
      • Jul 2010
      • 637
      there were very few cars that came with VR over there right? im pretty much using a thicker walled r32 motor, 2.8L / r32 head combo
      so i can boost more than 3.2L and more power and not blow up
      BEAST '90 CQ 24v VRT / O1E / v8 rear, HOLSET SUPER 40 http://www.theprojectpad.com/viewtop...1&t=193#p37887
      DD '86 4kq BLAZE, swapping aba/16vT and O1E http://www.theprojectpad.com/viewtop...1&t=201#p38264
      • pixsaudisex2
        • Sep 2004
        • 3110
        #48
        Must admit i suppose its the no substitue for cc, an if you have plenty to play with.
        • Mcstiff
          • Oct 2004
          • 504
          I think the "T" is important in chronology here; nobody was doing VR6Ts in the 90's save HPA (they may have in 99).
          1998 saw our tuning clientele expanding at an exponential rate. Our quest for more power landed us into a lifetime friendship with our technical partners at HGP, Germany. Together, we expanded their concept for a twin turbo V6 into what we offer around the world today. Showcased across all three RGT cars this last year, our collective efforts have raised the expectation of Volkswagen performance potential on a global scale.
          Since it seems the VR is not as common perhaps you guys will skip directly to the new I5s.
          1995 1PissedOff90sigpic1991 USDM CQ 7aT
          • my2000apb
            • Jul 2010
            • 637
            cc? displacement or credit card ahaha
            • pixsaudisex2
              • Sep 2004
              • 3110
              #51
              Bit a both,,,
              • my2000apb
                • Jul 2010
                • 637
                Originally posted by pixsaudisex2
                Bit a both,,,
                what project doesnt love lots of both
                • GazzaG60
                  • 4133
                  the biggest factors are
                  1. fuel
                  2. insurance.
                  Jamo is correct VRT over heren is not common. its lots of work, a non standard engine config and we get ripped off for fuel.
                  as the insurance to quote on a mk4 golf v6 turbo conversion or a modded 1.8t. the 1.8t is probly the only insurable option.
                  • my2000apb
                    • Jul 2010
                    • 637
                    1. fuel
                    2. insurance.
                    ok yeah def forgot about fuel pricing, its $$$$$$ over there
                    but for insurance, do you have to declare to insurance company a motor swap or a turbokit?
                    • Mcstiff
                      • Oct 2004
                      • 504
                      Is a 500hp VR6T really going to use more fuel than a 500 HP 1.8T?
                      • my2000apb
                        • Jul 2010
                        • 637
                        yeah the vrt will use more fuel even out of boost because it stillneeds to keep 2.8L stoich rather than 1.8L
                        obv. it takes fuel to make power but the vr will use more out of boost just as if you drove both NA
                        esp. as its prob easier to stay out of boost in the 1.8t as the 500 hp turbo on a 1.8 is def bigger and laggier than the "smaller" vr turbo
                          Yeah the 1.8T is an ultra efficient engine, in standard form it will do 40 mpg
                          • my2000apb
                            • Jul 2010
                            • 637
                            yes jamo for sure
                            the 2.8L is over 50% larger in displacement over the 1.8t
                            theres almost no way, other than mpg only style tuning, to make a 2.8 as efficient as a 1.8
                              If your building a 500 bhp car, whilst economy will be a concern it can't be the primary factor. My car is 500 bhp and does 28 mpg at present.
                              • Mcstiff
                                • Oct 2004
                                • 504
                                This is at ~1 BAR (sea level idle). At 1 BAR the 2.8 should make more power than the 1.8 (more fuel = more power cp).
                                Moving off idle lets say your at 1.5 BAR in your 1.8T this brings you to ~2.7L of air and x_CHP. Lets say your at lambda=1 so 2.7/14.7= 0.184 L of fuel per 4 cyl.
                                Now in the VRT to, approximately, match this 2.7 L of air your <1 BAR. For the sake of this discussion; lambda=1 so 2.8/14.7= 0.190 L of fuel per 6 cyl.
                                My point is that to do a unit of work your going to need a unit of fuel.
                                Obviously this is not 100% accurate (mass of air and vol of fuel) and technical differences between the engines could have an impact.
