why do i have to use two dump valves?
  • audiman
    • 4827
    LOL, same here
    Tom C - www.rcmr.co.uk
    Audi UR Quattro
    Audi 100 C3 2.0 5 cyl 115ps
    Audi B5 RS4 645ps 911nm
    • timucin
      • Nov 2003
      • 869
      • Country: Turkey
      forge dv006
      Quattro
      • 91_S2
        • 612
        Originally posted by Mark Halligan
        Rich,
        I placed it down low behind the side grill (RS2 bumper) in front of the oil cooler. This was too low, especially for the wet climate here. So now that I have it all apart again for the rebuild, I am going to place it higher up, I've taken the air-con compressor out so it will go where that used to be.
        Mark.
        Water was exactly what I was wondering about. Nice that we have you and Doug out there in front
        • Josh-stateside
          • 741
          Seemingly Dalback like's the HKS product for high boost applications.
          josh
          • Josh-stateside
            • 741
            I forgot to mention...
            I also read that dalback changes the ecu to read "density" from the maf sensor vs "flow" for high boost applications. It was in this months european car.
            Mihnea can you comment on this? Did I type that right?
            thanks
            Josh
            • Albert
              • 1500
              • Country: Poland
              #21
              i have taken out maf and signal is taken form map ... it works very good and I did not have to use exensive SQ maf for 4 inch inlet
              AKmotorsport.net - Manufacturing Motorsport parts that do the job. | Audi S2 on Facebook | Best way of reaching me is sending email to albert@akmotorsport.net
              • Josh-stateside
                • 741
                Can you go into more detail about this albert? Stock Ecu wiring? Do you tune motronic yourself or did some one else do this for you?
                Thanks
                Josh
                • Albert
                  • 1500
                  • Country: Poland
                  #23
                  http://www.perfectpower.com/products/smt6.asp It is good for 3B
                  for aby You have to wait for http://www.perfectpower.com/products/smt7.asp
