I got a couple of noob questions considering tuning of the ABY engine:
As I understand the upper limit of the factory pistons are around 550 bhp, can anybody confirm/disconfirm this statement.
Who produced the factory pistons, and who is the preferred supplier of aftermarket pistons, JE, Wössner or another?
When do you typically change the rods - tq, boost pressure, and what supplier is recommended.
When do you need to add another fuel pump, or do you simply switch the factory pump?
How sensitive is the ABY to fitting semi large injectors, 630-820 ml, and does anybody know BSFC of the ABY engine in different tunes?
When do you need to switch cams and/or revise the head? Is the ADU head different from the ABY head?
When is equal runner exhaust manifold design neccesary?
For what level of bhp is a 3" downpipe adequate?
When is boost creep a problem with the factory 30 mm wastegate?
When is improved intake manifold incl. bigger bore throttle body (VR6 OBD-II or larger) neccesary.
How "good" is the ABY at utilising potential turbocharger flow, I know that volumetric efficency changes with less restrictive set-ups, but do you typically need to dimension the chargers a little bigger than on paper, to reach a certain level of bhp?
How vulnerable is the 20VT to surge?
When is the factory ecu no longer suitable, and is VEMS the way to go then?
How much tq can the later 6 speed transmission handle?
When do you upgrade drive shafts?
Is the S2 factory differential setup, with open front/rear differential adequate in the 600 bhp range? I have searched the net for possible upgrades, but it seems that there are only a limited set of options including fitting the V8 rear differential. But do the factory set-up handle okay in combination with softer compound tires like the Toyo R888, and can the factory differential/drive shafts handle hard launch with tires like the R888?
Finally does anybody have head to head experience with a turbo like the Precision 5857, is the boost threeshold increased significantly with the Precision billet on a 2226 cc ABY?
A lot of questions, I know, but I will welcome any help in regards to the questions above.
Thanks!
Thanks!
), and this combination makes ~1.8 bar of boost around 5000 rpm, so I guess this turbo would make similar boost around or above this rpm range on the aby. If the addition of the Precision design and billet wheel would improve this I would prefer the Precision over the Garrett, if you get my point.
I have the same IC brilliant bit of kit
Turned out I had the earlier 30mm WG for some reason
With the 34mm unit on there Mihnea was able to map it. It depends so much on how restrictive the exhaust is of course.
