A friend of mine have some problem with his engine.
The engine blow out oil through the breather.
Does anyone know what may cause this???
And he also have one other problem.
Hes oil pressure is very low he has 1-1,2 bar at idle, and ~3bar over 4000rpm
I tryed to replace the pressure release spring with no bigger diffrence.
I dont know if the oil pump is bad or what may cause this. he is running with mobile 1 5-50 oil.
Hes brother have dismountet the engine once. so i dont know if there is anything wrong whith the lower part of the engine. i know that the top is ok..
Can any one help me with ideas?
