crank vr sensor resistance
  • QuattroFever
    • May 2006
    • 1360
    anyone know how many ohms I should see on testing a brand new crank vr sensor?
    Im getting 1000ohms on the one I can only assume has been there since day 1.
    Volcano ABY coupe
    Ant
  • gedu
    • Feb 2007
    • 295
    980ohm is spec, but can vary a bit between sensors. 1000ohms is well inside limits.
    edit: remembered wrong, spec is 'approx 1000ohm' checked from ELSA
    All quattro products have been dermatologically tested, and are safe for daily use.
    • QuattroFever
      • May 2006
      • 1360
      i want to know what a brand new one will show.
      Its never given trouble on motronic, Im running vems now which has shown to be a bit more picky over vr signal strength above noise. Im only getting 9.5-9.8millivolts when cranking. After modifing the bracket.
      I was getting 5.5-6 before and wouldnt get a spark at all so it may well only just be enough.
      It runs pretty good for now but it stumbles every now and again at idle. If fitting a new sensor could raise this by any amount it might help.
      I've read on megasquirt forums that 20mV is enough to rule out vr trigger issues.
      The closer i can get to that without modding the pin or welding the flywheel the happier i'll be.
      Volcano ABY coupe
      Ant
      • GazzaG60
        • 4133
        did you swap crank 2nd vr polarity for vems?
        • QuattroFever
          • May 2006
          • 1360
          yup.
          Volcano ABY coupe
          Ant
