Common subject but I need advice:
New built engine (stoker) and with low quality 10-40 oil an now with mobil 1 5w-50 still I get 0.8 bar at idle with warm engine. At 1500 rpm I have 1.8 bar and so on.
Is it common on new engines?
What should I check?
Can it be that further use the pressure will rise or is it something else?
Can it be that the sender is faulty?
Should I go to thicker oil like 10w-60?
Regards
Vasilis
Regards
Vasilis
