i got stock IC,and a custom 3" downpipe.
all my ignition parts should be as new¡¡ because i replaced them less than 3000kms¡¡
both knock sensors,distributor rotor,sparks plugs + their wires,new battery...only the single coil it is old
i will dont spend any $ in my engine now....because i have new plans for the next month
but i would like to discoverd what the fu_ck it is happend now,i want my car running perfect¡¡
i will take a look in Maf,small hoses,N75....
thank you for the suggestions
,for keep less boost pressure with k26/27 (i was some scaredd with it ,bigger turbo with stock internals ) but the last day i was testing,i screwed it ,and now it is 3mm bellow the waste cap...and the problem it is the same....
