Hi friend!
As I told you by phone, I think that the problem is in the wastegate.
First when the boost are going up there aren't any problem becouse the waste is closed but when the n75 starts his duty cicle to control de boost, open the waste's valve and the exhaust gas pass across the bypass to the downpipe, and I think in this moment, some exhaust gas flow across the body and guide of the waste's valve and come into the low chamber of the waste and causes an increase of pressure on the low chamber and pull up the waste's valve.... open totally the bypass, 0,4bar with OEM spring, and the only way to close the waste is reduccing the exhaust gas(decelerate) becouse the n75 can't close due to the exhaust gas are flowing across the body's valve and making the same job that the n75 does with the pressure air from the turbo to open the waste.
one question, what is the tecnical name for the body and guide valve?? I don't remember ....
Tell us something
As I told you by phone, I think that the problem is in the wastegate. First when the boost are going up there aren't any problem becouse the waste is closed but when the n75 starts his duty cicle to control de boost, open the waste's valve and the exhaust gas pass across the bypass to the downpipe, and I think in this moment, some exhaust gas flow across the body and guide of the waste's valve and come into the low chamber of the waste and causes an increase of pressure on the low chamber and pull up the waste's valve.... open totally the bypass, 0,4bar with OEM spring, and the only way to close the waste is reduccing the exhaust gas(decelerate) becouse the n75 can't close due to the exhaust gas are flowing across the body's valve and making the same job that the n75 does with the pressure air from the turbo to open the waste.
Tell us something
