Need good electrician...
  • spions
    • Oct 2009
    • 400
    Need good electrician near warrington how could fix all wiring problems with my coupe ABY engine.
  • lee_mac1
    • Aug 2010
    • 10
    what is the problem with it
    lee
    • spions
      • Oct 2009
      • 400
      Fuel relay don't swichin on.Don't have power.
      And injectors have 12v but don't work.Some time work.I don't know where is problem.I put 87a wire with O to have 12v on injectors
      • lee_mac1
        • Aug 2010
        • 10
        daft as it seems have you tryed a ingnition switch
        if no good let me know and will go over the wiring dirgrames
        lee
        • spions
          • Oct 2009
          • 400
          electricity is not my strong side.
          If I put 12v from side to fuel relay it's work.
          If someone could see and check what is wrong.
          • lee_mac1
            • Aug 2010
            • 10
            will have a look over the dia tomoz for you
            lee
            • spions
              • Oct 2009
              • 400
              Ok.TNX
              • lee_mac1
                • Aug 2010
                • 10
                o what year and model
                lee
                • spions
                  • Oct 2009
                  • 400
                  audi coupe quattro typ 85 1986
                  was 2.2KV now 2.2 ABY
                  • spions
                    • Oct 2009
                    • 400
                    So did you check?
                    • spions
                      • Oct 2009
                      • 400
                      Still can't start.
                      • lee_mac1
                        • Aug 2010
                        • 10
                        ok had a look for you have you changed the ignition switch it looks like that could be your problem
                        . ok i need you to make sure ALL the earths on the car are clean and tight there is a number of them under the dash and a few in the engine bay .
                        if you can do that and get back to me and let me know
                        lee
                        • spions
                          • Oct 2009
                          • 400
                          Ok.I will check today.
                          About ignition switch,what do you mean?
                          • spions
                            • Oct 2009
                            • 400
                            You mean this
                            • spions
                              • Oct 2009
                              • 400
                              And is it need only 208 fuel relay?
                              Because now i still have old one.
