thermostath modifying
  • s4_rider
    • Apr 2004
    • 44
    Got me a VR6 thermostath and indeed it helps.
    While driving it hits about 85 degrees.
    Thanks for the tip Ben.
    S4 Rider
    • RS2.pt
      • 155
      Originally posted by s4_rider
      In one of the threads I saw that drilling a hole in the thermostath is a quick (and dirty) solution to keep the watertemp a couple of degrease down.
      Has anyone more info/photo's ?
      Thanks in advance.
      Mine sits at 94 degC when driving and gets to 100-103 when stopping at the traffic lights.
      what I can say is that you ideia is not so strange as it looks. I had once a peugeot and the termostat had already a small hole on it, ver small say kind of 4mm diameter, that was from original.
      • jade
        • Jan 2005
        • 1811
        • Home: New Zealand Current: Spain
        What does anyone think about replacing front aux radiator (water one )
        with a bigger oil cooler .
        as its a bit hard to fit a bigger one down below ??????
        RS 2 580HP
          Speak to MarkH and do a search through the forum since he has already done just that.
          • puppetman
            • 70
            #20
            my temperature fluxuates alot. and it starts to overheat when in heavy traffic. so my mod for the week is .... remove thermostat.
            • jade
              • Jan 2005
              • 1811
              #21
              Cheers , i try and have a word with him
              RS 2 580HP
