Borrowed a cable and software to have a look at the ECU on the car but can't get it to connect. I know the car has been connected on several occasions during my ownership so I want to know what tricks I need to use. Been a bit frustrating so far
I've checked the fuse (21) and have the correct 2x2 connector to use the fuse box connections. Are there a second set of connections in the car on an ABY or can I use other wires? Is there a test proceedure to check the black or white connector?
The interface is being recognised but I can't go any further than that
Any tips? I've been told about ignition off / on to connect. All help gratefully received.
