Diagnostics / VAG Com help
    Borrowed a cable and software to have a look at the ECU on the car but can't get it to connect. I know the car has been connected on several occasions during my ownership so I want to know what tricks I need to use. Been a bit frustrating so far
    I've checked the fuse (21) and have the correct 2x2 connector to use the fuse box connections. Are there a second set of connections in the car on an ABY or can I use other wires? Is there a test proceedure to check the black or white connector?
    The interface is being recognised but I can't go any further than that
    Any tips? I've been told about ignition off / on to connect. All help gratefully received.
  • spink
    • 4382
    is this a new setup on your laptop?or has it been proved working on another car?more than likely a fault with how you installed it if not
    • vertigone
      • Nov 2009
      • 253
      • Country: France
      Hello Rusty,
      White line is for Data, black one is for power voltage
      Cable use to have a LED to show that power is ok
      plug the cable on you PC
      plug to the connector on car
      turn on ignition on car (no start needed)
      lunch software
      could you give us a screenshot of the error pop up ?
      91' S2 3B Pearl White
      • RolloS2
        • Oct 2009
        • 19
        is the car a runner? if not the immobiliser could be killing the power to the ecu so vag com would not see it.
          Cheers for the tips there. Lead has worked on another car, my computer hasn't. I turned off the anti-virus and firewall to try and help.
          The LED on the lead isn't illuminating so that's the first place to look, sounds like it's not getting power.
          Car is a runner, no immobiliser that I'm aware of.
          • mcandmar
            • Apr 2004
            • 5118
            You should always get a red light when plugged in, constant power. The black plug is + and -, the + shares the same fuse (S21) as the after run pump.
            91CQ20v - Gone to a new home
            93UR-S4 - The Magic Carpet
            94S2Bus - The Emerald Express
