I have bought a set of Main Bearings, Coated, Audi I5 10v/20v from 034motorsport. They all fit nice except the one with the thrust washers:corey:. Look at the photograph. Someone ever had a problem with this?
I have ordered a lot from 034 incl the main and rod bearings. The rod bearings are oem rs2 one's. It looks i have to order another set of mains. You say Aelred sells them? I really didn't know that.
Hy,
I have bought a set of Main Bearings, Coated, Audi I5 10v/20v from 034motorsport. They all fit nice except the one with the thrust washers. Look at the photograph. Someone ever had a problem with this?
The bearing make up is the same for all I5 engines on the mains it is only the big end bearings that are sputter on the rod side, cap side is the same again. However as previously mentioned the mains and thrust should be a seperate entity. The one piece ones tend to eat into the crank as they have less contact surface area.
The NM / 7A are softer than the 3B / ABY / RS2 ones
NA ones are 034 198 491 A
Turbo ones are 034 198 491 C
This is from when I did my research before buying the glyco competition bearings from aelred
As well as the different materials used in the various available mains shells, there are also some subtle differences between various bearings with respect to the grooving on the bottom mains shells.
The OEM shells listed for the turbo engine also have longer 'half' oil grooving on the lower shells.
Now it been a while now since I have played with engines but I am fairly sure that the I5T OEM turbo mains do have a hardened lower shell ...
Yep - hardened for S2/RS2 applications... seek ye a KolbenSchmidt (KS) catalog - the uprated ones for RS2 are 'sputter' type which is name for process by which they apply the hardened coating. Pretty sure Glyco do the sputter types too.
