Psshiiit ! when opening fuel tank
  • vertigone
    • Nov 2009
    • 253
    • Country: France
    Hello Guys !
    Nedd your help for this
    When i open my tank for fuel refill, I hear a PSSHIIITT like coke can
    I can't find the truth about this : some says it's normal other says problem
    I ve found schematics about fueltank but I don't know how it would work, is there a kind of "open air" things to avoid pressure in tank ?
    hope someone can explain
    91' S2 3B Pearl White
  • bernsaudi
    • Feb 2007
    • 592
    mine doesn't do that and never has....got to be a blocked breather pipe.
    • s2driveruk
      • 12696
      mine has from day one (10yrs ownership)...again not sure if a problem or 'feature' of the car
      Certainly doesn't appear to affect anything to do with mechanical operation of the car or fuel circuit, pressure regulator and pump are original etc...
      David
      1992 3b S2 Coupe
      • veneto rs2
        • Jun 2006
        • 1022
        • Country: Veneto
        On my RS2 no pssshhhhiitt of any type....
        I do have this kind of noise on the Cabriolet thoug.....and on my old S2 3B I remember the same noise..... also the Cabbie does smell of petrol inside the cabin, the smell disappears when I switch on the engine, any suggestion on this smell problem?
        Stefano
        http://www.audisportclub.com/
        http://www.s2forum.com/forum/vbgoogl...227295&zoom=16
        • vertigone
          • Nov 2009
          • 253
          • Country: France
          1 vs 1 again
          I'm quite worried about tank damage due to pressure inside
            Vacuum or pressure building in the tank cannot be a good thing... The tank is supposed to breathe - it should vent any fumes via the carbon canister and EVAP solenoid.
            • s2driveruk
              • 12696
              i think its pressure to be honest as its higher when the ambient temperature is high
              1992 3b S2 Coupe
              • Rocco
                • Aug 2007
                • 6393
                • Country: Spain
                +1 me too¡¡ and whem the days are hot more¡¡
                i have this "issue" in my car. but normally i never smell petrol inside
                i have a new fuel machine in my farm and whem unplug for ad petrol always has pressure ...and the machine has around 1 year,always did it
                  mine has always done this, nothing has changed since i binned the EVAP line and now vent direct to atmosphere under the rear bumper Dunno if the breather tank thing and rollover protection valve are jammed shut or somthing?
                  • s2driveruk
                    • 12696
                    do we all have the same cap i wonder
                    1992 3b S2 Coupe
                    • vertigone
                      • Nov 2009
                      • 253
                      • Country: France
                      what about drilling a little hole in the cap ?
                      • BLAMM0
                        • Aug 2010
                        • 337
                        • Country: Lithuania
                        Hello, has anyone found a solution for this? my car also does this sound.
                        • Colesy
                          • Feb 2009
                          • 2980
                          For the record my S2 and the cabriolet both do this.
                          • quattrostyle
                            • Oct 2006
                            • 6229
                            why? If everything works as it should I won't be looking for a 'solution' My cabby does it aswell.
                            • re2500
                              • May 2007
                              • 2185
                              My coupe has always done this also. Ive never really given it a thought TBH.
                              Black B3 1990 CQ 2.3E converted to ABY & 6spd. (301bhp) - Now Sold
                              "Difficult is worth doing"
